WEG at the SPS 2025
Smart gearbox selection
'Gear ProSelect' from WEG is aimed at all those who are regularly involved in the selection and design of gearboxes and geared motors in mechanical and plant engineering, including design engineers, technical purchasers and OEMs.
© WAY
At the heart of the tool is an intuitive user interface that guides the user step by step through the selection process. It is web-based and can be used immediately without installation. Depending on the selected application, the software takes into account necessary parameters such as the speed and mass of the conveyed goods and incorporates these directly into the product recommendation. Mechanical and thermal validations ensure additional safety and reliability in the design. Technical data sheets, dimensional drawings and specifications can be downloaded directly from the tool. The software also offers modern visualization options: With the help of interactive 3D models and an augmented reality function, the selected gearboxes can be viewed virtually in a real environment and integrated directly into your own design environment. Users of the 'WEG-Easy' system also have an integrated ordering process at their disposal.
Hall 3A Stand 451
Lean technology
Easy to implement
Nabtesco
The gearbox makes the robot
How precise, strong and fast a robot is depends on the performance of the gearboxes used. In the white paper, you can find out what is important in the design and how your robot can also benefit from the properties of Nabtesco gearboxes.
Faulhaber
Compact motion control system
The Motion Controller 22xx...BX4 IMC from Faulhaber is already integrated in the brushless motors of the '22xx...BX4' family. The increase in length compared to the individual motor is 18 mm and includes a fully-fledged servo controller and a 12-bit...
