Servomotors
Quelle: KEB Automation | Inka Krischke,
Use in harsh environments
Servomotors from KEB's DL3 series are designed for highly dynamic motion tasks. Here, the version with special epoxy coating 'Steel it' is suitable for installation positions with direct weather influences and with slight chemical stress on the surface from the environment.
© KEB Automation
Five motor sizes from 55 to 190 mm with rated torques from 0.5 Nm to 70 Nm are available. Four motor sizes with output torques from 5 Nm to 720 Nm are available in the special coating as servo geared motors in combination with the 1- and 2-stage planetary gearboxes for adjusting torque and speed. The range of transmission ratios extends from i=5 to i=40.
Baumüller
Scalable servo controllers
According to the manufacturer Baumüller, the 'b maXX 6000' servo controllers offer more performance and scalability. More performance is ensured, for example, by safety functions that have been specially developed for applications with high dynamic...
