Getriebebau Nord at the SPS 2024
Frequency inverter in booksize format
© Nord Drivesystems
With the 'Nordac Pro SK 500P', Nord Drivesystems has a control cabinet inverter that is available in variants in a power range from 0.25 to 22 kW, which can be assigned to different requirements in different industries.
As with all inverters in the 'Nordac Pro' series from Nord Drivesystems, one of the key elements is the integrated multi-protocol Ethernet interface. This allows the control component to be integrated into various networks without retrofitting. This includes the Profinet, Ethercat, Ethernet/IP and Powerlink protocols. Depending on the model, other protocols are also covered. The inverter can also be parameterized without voltage via a USB interface. The integrated PLC reacts independently to changes in the system processes and is therefore able to relieve the higher-level control system. The 'Posicon' positioning function performs various positioning tasks. It can control both relative and absolute positioning using incremental or absolute encoders. Sequential positioning of up to four axes is possible via parameter set changeover. The inverter has vector control with an overload reserve of 200 %.
Hall 3A, Stand 451
Drive technology
Triton Partners takes over Flender
Global investment firm Carlyle has signed an agreement to sell Flender, a provider of mechanical drive technology, to Triton Fund 6, advised by Triton. The terms of the transaction were not disclosed and is expected to close in the fourth quarter of...
Humanoids
Schaeffler cooperates with VinDynamics
Schaeffler and VinDynamics, a company of the Vietnamese Vingroup, have agreed on a strategic partnership in the field of humanoid robotics. The collaboration focuses on the development and supply of planetary gearboxes, central components of...
VDW
German machine tool industry stabilizes
After two years of noticeable investment restraint, the German machine tool industry is showing the first signs of stabilization. Overall, however, incoming orders in 2025 remained slightly below the previous year's level.
KEB Automation
Drives with air cooling
KEB Automation is expanding its drive portfolio for turboblowers, compressors and other high-speed applications: In addition to liquid-cooled high-speed drives, an air-cooled version will also be available in future.
