Oriental Motor
Space saving for two-axis systems
The new two-axis driver from Oriental Motor is 7 cm shorter in length than the previous model. It controls the AZ motors equipped with a mechanical absolute value sensor.
The closed-loop stepper motor drives from Oriental Motor are also used as drives in actuators such as linear guides, cylinders, rotary tables or rack and pinion systems. The two-axis driver is Ethercat-compatible and can be easily connected to the fieldbus network via the Ethernet cable. The setting and execution of operating data as well as the setting of various parameters, the output of alarm information and monitoring functions can be controlled via the network. Commands and status messages are transmitted in real time. This allows the movements of several synchronously operating stepper motors to be executed precisely. Appropriate versions of the multi-axis driver are available for applications with three or four axes. All multi-axis drivers are operated with 24/48 V(DC).
