ebm-Papst
Yvonne Junginger,
Solutions for automation
ebm-Papst presents solutions for automation in drive and ventilation technology.
© ebm-Papst
These include the ECI-63 internal rotor motors, equipped with an Ethercat interface. High-performance interface electronics including a multi-protocol chip in the drive housing have also been added. The advantages for decentralized drives lie in the synchronization of several axes, the reduced integration effort and a space-saving design in the machine.
The new RadiPac series from ebm-Papst can also be used for high-pressure applications. The impeller reduces flow losses and further lowers noise levels. To accommodate different installation situations, the series is available in a standard and a short version. Both versions are available as a motor-impeller combination or as a ready-to-install plug & play solution with a support spider design.
The DiaForce diagonal fan with integrated DC motor enables 50 % more air performance with 6 dB(A) less noise. By drawing in and blowing out air in an axial direction, turbulence can be reduced and the pressure build-up increased. Possible areas of application include data centers or base stations for mobile communications, autonomous driving or artificial intelligence.
WEG at the SPS 2025
Smart gearbox selection
'Gear ProSelect' from WEG is aimed at all those who are regularly involved in the selection and design of gearboxes and geared motors in mechanical and plant engineering, including design engineers, technical purchasers and OEMs.
Lean technology
Easy to implement
