Energy recovery
Quelle: Lenze | Inka Krischke,
Separate feed-in and feedback paths
Lenze is launching a regenerative unit in two power levels - with 12/24 and 26/48 KW. By separating the feed-in and regenerative paths, both branches can be designed separately, which enables exact dimensioning according to the system requirements.
© Lenze
The regenerative power can be scaled by connecting several modules in parallel. According to the supplier, the compact regenerative power supply has an extremely short amortization period thanks to its high efficiency and the absence of external filters. Retrofitting in existing machines is also possible. Typical areas of application are, for example, hoists, where a relatively high amount of energy is temporarily generated during the lowering of the load, as well as test benches, where the energy of the test object must be dissipated continuously due to the principle.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
