Geared motors
Rated torques up to 5000 NM
WEG is expanding its WG20 geared motor range to include helical, parallel shaft and helical bevel gearboxes for rated torques up to 5000 Nm.
The gearbox housings are made of gray cast iron and are so robust that they are also suitable for applications such as in the steel and heavy industry. Thanks to the expansion of the geared motor range, applications with higher torques can now also be covered. Thanks to the intelligent pinion construction kit, the gearboxes in the series are designed with two or three stages in a large reduction range. According to the supplier, this results in very low losses and the gearboxes are particularly energy-efficient. In addition, the variant-optimized gearing concept enables high output speeds and the implementation of a wide speed range for all gearbox sizes.
