Kollmorgen
More smooth running, precision and torque density
The stepper drive 'P80630-SDN' from Kollmorgen supplies and controls stepper motors that are operated with 24 to 75 V(DC) with up to 5.5 Aeff current per phase (7.8 Aeff maximum value).
© Kollmorgen
The stepper drive is suitable for labeling machines, rotary table drives, CNC machines, packaging systems, pumps and other single or multi-axis systems that require low-speed, point-to-point motion control for fixed loads. According to Kollmorgen, the controller offers improved position accuracy and achieves 10% more output current in a 60% smaller package that is up to 34mm shorter than the '6410', depending on the model. Conventional single-ended or differential clock/direction inputs (user-defined pulse train required) or CW/CCW command inputs are supported. DIP switches can be used to set the motor phase current, idle current reduction and step resolution of up to 1/128 microsteps. A dedicated enable input and an error output allow the drive's power stage to be controlled and errors to be monitored.
