Stainless steel motors
Quelle: Groschopp | Inka Krischke,
Integrated planetary gearbox
Groschopp has developed stainless steel motors with integrable planetary gears that meet the current state of the art in terms of hygienic safety.
© Groschopp
As the gearbox was integrated into the stainless steel housing, it was possible to use an inexpensive standard planetary gearbox instead of an expensive stainless steel gearbox. The flexible design of the drive allows attachments such as controllers or motor brakes to be implemented quickly. The drives are based on the 'ESK Silver-Line' series or the newer 'ESKH' stainless steel motors, which were designed in accordance with the EHEDG guidelines. The stainless steel motors comply with protection class IP69K, are highly resistant to chemicals and easy to clean. Regardless of the installation position, there are no flat surfaces, all internal and external radii are greater than 3 mm and there are no weld seams or unevenness caused by screws. The surface roughness is less than Ra 0.8 µm. Thanks to the hygienic design without corners and edges, no dirt pockets form and bacteria can be easily removed.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
