Drive controller
Quelle: KEB Automation | Inka Krischke,
Integrate safety
The current drive controllers from KEB combine servo and inverter operation and offer extensive safety functions for the integration of safety in plant and machine automation.
© KEB Automation
For example, the Combivert S6 single-axis servo inverters with a peak current of up to 250 % cover the power range up to 5.5 kW; they are primarily aimed at applications with high dynamics and overload. For the power range between 4 and 400 kW, Combivert F6 is initially available in four sizes, which serve motor outputs up to 90 kW. The universal S6/F6 drive controllers are available in two technical versions with identical functions: K-Control has everything on board, from Ethercat to CAN, STO and the 'Multi Encoder Interface'; A-Control offers the flexibility of various safety modules and real-time Ethernet connections. In addition to CAN, both Ethercat and Profinet are implemented as Ethernet interfaces in one device simply by means of a software switch. With the certified safety module 3, the series covers a range of safety functions that can be configured and parameterized using the 'Combivis 6 Safety Editor' as part of the KEB development environment. Open-loop or closed-loop operation is always available for all common motor technologies. From 30 kW, the F6 series provides both air and liquid cooling - both in control cabinet installation or through-hole versions.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
