SPS 2019New products in Nuremberg
What new products did the exhibitors present at SPS 2019? Computer&AUTOMATION provides an overview of what awaited visitors to the Nuremberg exhibition halls this year.
53 of 75
39_3D contour measuring system from Leuze Electronic
© Leuze electronic
With the CMS 700i, Leuze electronic is launching a 3D contour measuring system that is based on the 'CML 730i' measuring light curtains and can be customized. he complete system includes all components under one article number: the control cabinet, mounting elements and connection technology. It measures the contour and position of any objects, regardless of their shape and surface properties. Even flat objects such as polybags can be measured precisely without installing a camera. The minimum dimensions for height, width and length are 5 mm × 50 mm × 50 mm. The object information allows, for example, the loading of a pallet or the optimization of incoming goods, while at the same time bulges or protrusions of the object are reliably detected, which could lead to problems or system downtime during automated storage. The intuitive WebConfig simplifies commissioning and remote maintenance by the customer. Thanks to the Ethernet TCP/IP or Profinet interface, integration of the 3D contour measuring system is guaranteed. Peripheral data, such as from scales or barcode scanners, can be collected by the system via an open Ethernet interface and looped through with a time stamp.
53 of 75
