ABB MotionFrequency inverter controls motors up to 22 kW
ABB is expanding its family of Machinery Drives with a compact, robust and adaptable frequency inverter for machine builders.
Sieb & Meyer presents the SD4S, SD4M and SD4B, the latest models in the SD4x series of frequency inverters for high-speed applications. The SD4B, successor to the 'SD2B plus', is suitable for use as a highly dynamic servo drive for the operation of rotary and linear low-voltage servo motors as well as for the operation of high-speed low-voltage synchronous and asynchronous motors. In the high-speed range, the frequency inverter allows sensor-based operation of motors with a superimposed synchronization function based on 24 V synchronization signals.
This allows several high-speed motors to be operated synchronously in master/slave mode. The SD4S is available in numerous sizes in the 230 V class and 400 V class. Overall, these devices cover the power range (1.4 to 55 kVA) of the SD2S series or extend it upwards and downwards (0.8 to 66 kVA), while the SD4M three-level inverters are suitable for turbo compressors and turbocompressors, for example.
SPS 2022: Hall 4, Stand 230
