Faulhaber
Andrea Gillhuber | Andrea Gillhuber,
Hollow shaft motor with large aperture
The DM66200H series from Faulhaber is a hollow shaft motor with an internal opening (aperture) of 40 mm.
© Faulhaber
The motor addresses Faulhaber applications in which a large aperture is required, e.g. to feed cables through. The rotor runs around the opening and directly drives the mechanics arranged around it without a gear ratio. The company's stepper motor technology is used here.
Despite the large aperture, the moving mass of the rotor remains low, so that speeds of up to 2000 min-1 are possible. The motor achieves a dynamic torque of up to 180 mNm. With a resolution of 1.8° in full step, it can perform positioning tasks precisely in an open loop.
Originally developed for applications in precision optics, the motor can also be used for impellers and prostheses, in robotics and for a wide range of control and positioning tasks.
Faulhaber
Motor series extended
Faulhaber has expanded the BXT flat motor series to include gears that are matched to it as well as integrated encoders and speed controllers, which are also unusually short in the axial direction, according to the manufacturer.
Lazy bonnet
New management from January 2022
The management structure at drive supplier Dr. Fritz Faulhaber will change in January 2022. The previous managing directors will hand over responsibility to a five-member management team led by Karl Faulhaber due to their age.
Nord Drivesystems
Power range up to 4.0 kW
The IE5+ synchronous motor from Nord Drivesystems is also available in a ventilated or smooth version up to an output of 4.0 kW. On request, the motors are available with a very smooth surface and the 'nsd tupH' surface finish.
