SEW-Eurodrive at the SPS 2023
Ethernet-based communication interfaces
With 'Movimot performance ELV', SEW-Eurodrive is expanding its range of decentralized compact low-voltage drives with 48 V (DC) supply to include network-compatible versions.
© SEW-Eurodrive
According to SEW-Eurodrive, this portfolio expansion combines the advantages of compact extra-low voltage geared motors with the benefits of the 'Movi-C' communication platform and the 'Movisuite' engineering tool. 'Movimot performance ELV' combines a permanently excited synchronous motor with a dynamic drive controller and high-performance communication interface. Up to 350 % of the continuous motor torque is temporarily available for acceleration processes or material flow peaks. All connections are made via M12 connectors with different coding. The drives are optionally available with a Profinet, Ethernet/IP or Ethercat interface. They enable horizontal communication between the drive modules and, at the same time, vertical communication to the system control level.
Hall 3A, Stand 411 + 711
