Rose+Warrior
Comprehensive protection against corrosion
For automation solutions in areas where condensation and dripping water forms due to the ambient or production conditions, RK Rose+Krieger has added a corrosion-protected version to the 'RK MonoLine' series of toothed belt-driven linear axes.
© Rose+Warrior
The compact linear units in the size 80 series are specially designed for highly dynamic, repeatable pick & place, palletizing, loading and unloading processes in the medium load segment. According to the manufacturer Rose+Krieger, they combine high rigidity with smooth running behavior, a repeat accuracy of ±0.05 mm and a maximum acceleration of 20 m/s². All parts of the corrosion-protected RK MonoLine Z80, which are made of steel in the standard version, have been replaced with stainless steel components. The toothed belt is made of polyurethane with a stainless steel cord. In addition, prefabricated drain holes are provided in the toothed belt deflection for vertical use of the axis, which the customer can open if necessary to allow condensation to drain off.
RK Rose+Warrior
Change in the management
Björn Riechers will take over the management of RK Rose+Krieger and the management of the Automation Modules division of the Phoenix Mecano Group from Dr. Gregor Langer on June 1, 2023. Langer has managed the company's business since 2021.
