Wenglor
Ultrasonic sensors in stainless steel housing
With the 'U18T' ultrasonic sensors, Wenglor offers a series in the standard M18 design in a stainless steel housing that is suitable for detecting shiny, transparent and dark objects and, according to the supplier, also reliably detects reflective surfaces.
© Wenglor
With the IO-Link interface, the ultrasonic sensors from Wenglor enable flexible integration into various systems. The sensors are available in versions with switching and analog outputs. Their operating range is up to 1200 mm in reflex mode and up to 2400 mm in barrier mode. Various operating modes are available to adapt to different application situations: The automatic synchronous mode is designed for the delay-free detection of objects. In this mode, up to 32 sensors can be operated in parallel. Multiplex mode is suitable for level monitoring of large areas and allows up to 16 sensors to be operated together without interfering with each other. The stainless steel housing is robust against environmental influences thanks to protection class IP67.
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
Sick
Award for sustainability management
Sick has received a platinum medal in the EcoVadis sustainability ranking. This puts the provider of sensor-based automation solutions in the top 1 percent of more than 130,000 companies worldwide that have been assessed over the past twelve months.
Vega Grieshaber
Chip start-up founded
The start-up milli IC from Karlsruhe specializes in the development of ASICs - and Vega Grieshaber is 'on board' to ultimately develop radar measuring devices with radar frequencies of more than 100 GHz.
