ipf electronic at the SPS 2023
Programmable flow sensor
With the 'SS500020' in protection class IP67, ipf electronic presents a thermal flow sensor with M12 connector for measuring the flow rate and temperature (0 to +80 °C) of water-based media in pipes.
© ipf electronic
Due to the parameterizable pipe diameter (15 mm to 250 mm) and the applied flow rate, the calculated value is visualized in l/min, m³/h, m/s or °C in the 3-digit display, which can be rotated by 180°. The sensor from ipf electronic, which is pressure-resistant up to a maximum of 60 bar, offers a response time of <1 s and is insensitive to temperature fluctuations. To monitor the flow status and temperature, the sensor integrates either two digital outputs (PNP/NPN-NO/NC + pulse) or an analog output (4 to 20 mA), which can be individually programmed. The device also has a teach-in input, for example to carry out a quick calibration in multi-substance operation. The sensor can also be parameterized via IO-Link. There are three different adapters with different process connections.
Hall 7A, Stand 400
AMA Association
Slight decline in incoming orders
The sensor and measurement technology sector recorded no change in turnover in the third quarter of 2024 compared to the previous quarter. However, turnover fell by 10% compared to the third quarter of 2023. Incoming orders were 2% below the level...
Vega Grieshaber
Chip start-up founded
The start-up milli IC from Karlsruhe specializes in the development of ASICs - and Vega Grieshaber is 'on board' to ultimately develop radar measuring devices with radar frequencies of more than 100 GHz.
