Mechanical position detection
Quelle: Microprecision Electronics | Inka Krischke,
Operating temperature between -40 and +130 °C
The mechanical sensors of the MP600 series from Microprecision have been developed to detect two positions using just one device. The distance between the two positions can be adjusted to the user's application between 0.3 and 1.5 mm.
© Microprecision Electronics
Fixed NC and NO contacts work without measurable hysteresis, the repeat accuracy is better than 5 μm. Depending on the cable selection, the operating temperature can be between -40 and +130 °C. The cable termination is available with an M12 plug. The patented switching mechanism is designed for voltages up to 30 V(DC), is self-contained and can be easily integrated into countless housing shapes. The IP67-tight standard housings are available in sizes M8 and M12 with pin or ball actuator.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
