Kistler
Measurements including temperature compensation
The piezoresistive absolute pressure sensor 4017A from Kistler is suitable for engine development as well as hydraulic and pneumatic applications in both cold and hot environments.
© Kistler Group
It comes in a size of just M5x0.5 and, according to the manufacturer, has been specially designed for maximum robustness and accuracy. Its oil-filled measuring cell is media-separated by a steel diaphragm and provides a high level of media compatibility for both gaseous and liquid media. Thanks to a temperature-compensated operating range of -20 to +140 °C, the sensor can also be used for cold tests. The digital temperature compensation ensures high accuracy (≤1 % FSO) even under harsh environmental conditions. An integrated temperature measuring element monitors the sensor status during measurements (operating temperature range: -40 to +180 °C). The sensor is available with different measuring ranges for pressures up to 5, 10, 20 or 50 bar - optionally also with ATEX certification (Zone 2) for applications in potentially hazardous areas.
Kistler at Automatica: Hall 5, Stand 205
Kistler
WLAN-capable process monitoring
Kistler has added new features to the ComoNeo process monitoring system for integrated injection molding production: The pressure curve in all cavities can now be monitored more precisely with a process-adapted envelope curve.
Kistler
Return to growth expected in 2021
The shrinking automotive market and the global downturn caused by the coronavirus pandemic have also had an impact on the Kistler Group, which generates over 70% of its revenue from automotive manufacturers and suppliers, who have been particularly...
Kistler
IO-Link technology included
With the 5028A charge amplifier, Kistler is launching a charge amplifier that can output analog signals from piezoelectric sensors as digital measurement data using IO-Link technology.
Kistler
Testing on a new level
In a research project, Kistler is investigating the possibilities of fully automated optical quality assurance in injection molding production. In addition to the system design, the project is looking at how data synchronization and the adaptation...
