a.b.jöddenWorking at temperatures from -40 to +120 °C
A.B.Jödden offers inductive displacement transducers and fine probes for measuring displacements of up to ±10 mm with resolutions in the µm range. The plunger of the fine probes is pressed into the rest position by an integrated spring or, in the case of larger measuring travels, by an external spring.
© Carlo Gavazzi
THE NRG system
- Up to 32 digital solid-state relays and contactors on one control unit/gateway
- Flexible due to compact modular design
- System with real-time diagnostic function
- Direct data access via remote customer support
- Predictive maintenance through early detection of load faults
- Real-time monitoring of energy consumption
