a.b.jöddenWorking at temperatures from -40 to +120 °C
A.B.Jödden offers inductive displacement transducers and fine probes for measuring displacements of up to ±10 mm with resolutions in the µm range. The plunger of the fine probes is pressed into the rest position by an integrated spring or, in the case of larger measuring travels, by an external spring.
© HMS
Remote maintenance solutions for industry
- Collect machine data from different locations
- Simple commissioning even in complex IT environments
- Historical data for analysis applications
- Display & monitor machine data in real time (alarms, HMI, etc.)
- Easy integration of machine data into leading IoT platforms
- Benefit from a first-class remote access solution
More about HMS Industrial Networks and more about ewon
