Current productsNews about sensor technology
What would the smart factory of today and tomorrow be without sensors? Sensors are indispensable as the basis of every industrial production system. Computer&AUTOMATION has summarized current trends from spring 2017 in a picture gallery.
8 of 27
ATM.mini from STS
© STS Sensor Technik Sirnach
With the ATM.mini, STS is launching a precision pressure transmitter in vest pocket format. With measurement accuracy values of 0.5 % total error over a temperature range of -40 to +125 °C, pressures of up to 100 bar are reliably displayed. According to the supplier, a stainless steel housing and overpressure resistance ensure durability even under harsh conditions. The measuring instrument weighs just 50 g. Thanks to its external dimensions of 17.5 mm × 49 mm, the pressure transmitter can be easily mounted on small and angled components. Various process and electrical connections are available. For the output signal, customers can choose whether the measured values are transmitted via a current signal (mA) or a voltage signal (V(DC)) are transmitted.
8 of 27
