ipf electronicMeasuring flow rates in pipes
With the 'SM89x-SM9xx', ipf electronic is launching a new series of magnetic-inductive sensors made entirely of stainless steel.
2 of 14
© Rafi
Rafi's Micon 5 series of short-stroke pushbuttons is now also available in the Micon 5 Safety version with a two-channel contact system. The push-buttons in the series have the same dimensions as Micon 5, but integrate two isolated NC and NO contacts. Thanks to an optimized sealing system, the Micon push-buttons achieve protection class IP54 or IPx7 and, with a temperature resistance of -40 to +125 °C, meet the current requirements of the automotive industry. They have an SMT connection for PCB assembly and are suitable for potting, painting and nano-coating. Like the standard versions, the push-buttons offer a switching-safe gold contact system and tactility: depending on the version, the push-buttons, which are available for different actuating forces, guarantee up to 1 million switching cycles. Thanks to the identical dimensions, the Micon-5 accessory range of plungers and keycaps is also available without restriction for the new version.
SPS 2022: Hall 7A, Stand 544
2 of 14
