ipf electronic at the SPS 2022Detection with UV light
The OY380520 and OY380523 luminescence scanners from ipf electronic are optical sensors that use UV light to detect luminophores in different materials, thereby triggering a switching operation.
2 of 14
© Rafi
Rafi's Micon 5 series of short-stroke pushbuttons is now also available in the Micon 5 Safety version with a two-channel contact system. The push-buttons in the series have the same dimensions as Micon 5, but integrate two isolated NC and NO contacts. Thanks to an optimized sealing system, the Micon push-buttons achieve protection class IP54 or IPx7 and, with a temperature resistance of -40 to +125 °C, meet the current requirements of the automotive industry. They have an SMT connection for PCB assembly and are suitable for potting, painting and nano-coating. Like the standard versions, the push-buttons offer a switching-safe gold contact system and tactility: depending on the version, the push-buttons, which are available for different actuating forces, guarantee up to 1 million switching cycles. Thanks to the identical dimensions, the Micon-5 accessory range of plungers and keycaps is also available without restriction for the new version.
SPS 2022: Hall 7A, Stand 544
2 of 14
