Novotechnology
For commercial vehicles and mobile machinery
Novotechnik's position sensors with CAN-SAE-J1939 interface can be used universally and are not limited to defined sensor functions in the vehicle. These include the TM1 absolute position sensor with plug-in or slide-in flange.
© Novotechnology
The displacement transducer from Novotechnik works contactlessly according to the magnetostrictive measuring principle and can be integrated directly into hydraulic cylinders. It is protected against HF fields up to 200 V/m in accordance with ISO 11452-2 and therefore exceeds the E1 requirements of the German Federal Motor Transport Authority. The RSA-3200 Hall angle sensor, which also measures without contact, is particularly suitable for safety-relevant applications in extreme environmental conditions. The RFE-3200 angle sensor, which is often used in high-temperature applications (up to +125 °C), also works according to the Hall principle. The robust RFC-4800 series single-turn encoders are compact, easy to install and measure the angle of rotation absolutely over 360° with a resolution of 14 bits.
Kistler
Solid sales development in 2025
The Kistler Group generated sales of 424 million Swiss francs in 2025. With a currency-adjusted decline of 1 percent, or 5 percent in Swiss francs, the company was able to keep sales stable compared to the previous year.
