Baumer
Encoders for existing systems and new projects
Baumer is expanding its product portfolio for positioning tasks with the fieldbus encoder 'EN580C'. The EN580C optical multiturn encoder is backwards compatible.
© Baumer
The encoder's features include an accuracy of up to 0.01° and the option of convenient application-specific parameterization (gear function, dynamic PDO mapping). Thanks to the flexible cabling with fieldbus cover, it can be easily integrated and commissioned using address switches (node ID, baud rate). During maintenance, the old fieldbus encoder can be quickly and easily replaced with the new model. In addition to use in existing systems, the Baumer encoder is also suitable for new projects with fieldbus protocols. Fields of application for the fieldbus encoder include factory automation, mechanical and plant engineering and intralogistics.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
