Sick at the SPS 2023
Display with symbol-supported user interface
The optical distance sensor 'DT80' from Sick achieves a measuring accuracy of ±2 mm, its maximum resolution is specified as 0.1 mm.
© Sick
The time-of-flight sensor can reliably detect natural objects with a remission of around 90 % at a distance of up to 80 m and measure their distance to the sensor. The laser class 2 sensor also achieves a range of 14 m on deep black surfaces with only 6 % reflection. According to the manufacturer Sick, 'Icons inside' and user-friendly menu navigation ensure intuitive setting and operation of the distance sensor via the TFT color display. Alternatively, the sensor can also be set to the respective application via IO-Link or with the help of the 'Sopas' software. Four LEDs visualize operating and switching states. Thanks to its dimensions of 65 mm x 33 mm x 57 mm (HxWxD), the sensor is space-saving. The metal housing made of die-cast zinc, the viewing window of the sensor made of PMMA, protection classes IP65 and IP67 as well as the high specified shock and vibration resistance enable the sensor to be used even under harsh operating and environmental conditions.
Hall 7A, Stand 340
Review
The top articles in June 2023
Interest in the topic of artificial intelligence continues unabated and is also reflected in our most-read article of the month of June: two youngsters who have set out to overcome fears of AI technologies lead the ranking. The top 10 at a glance.
Leuze at the SPS 2024
Double focus
With the 'DCR 1048i OCV', Leuze is expanding its Simple Vision portfolio with a further functionality: The sensor can both read 1D/2D codes within an application and check the quality of a print using the OCV method.
