ipf electronic at the SPS 2023
Available in three lengths
ipf electronic offers 3-pole M8 couplings for sensor-actuator cables with LED display in a straight design. The compact solutions are available with single or double assembled connection cables.
© ipf electronic
The LEDs integrated in the coupling signal both the connection to the operating voltage (green) and the status of the PNP switching output (yellow). Due to the design, the LEDs are visible from one direction at a time. The simply assembled sensor/actuator cables from ipf electronic with free cable ends are available in three lengths: 2 m (VK200275), 5 m (VK500275) and 10 m (VKA00275). Users have more choice with the double-terminated cables with lengths of 0.3 m (VK030F76), 0.6 m (VK060F76), 1 m (VK100F76), 2 m (VK200F76) and 5 m (VK500F76). All cables with a polyurethane cable sheath are suitable for highly flexible and therefore often harsh industrial applications, as they are weld-resistant, oil-resistant, suitable for drag chains with 5 million bending cycles and also free from silicones.
Hall 7A, Stand 400
Most read
The top articles in June 2024
The most-read articles in June illustrate the power of the automation industry. Read more about the technologies and strategies that are gaining ground in areas such as networking, robotics, safety and the process industry.
Endress+Hauser
Digital twins on the rise
Digitalized processes along the entire value chain require a digital twin. Behind this virtual image of a real object is a wealth of data and algorithms that are used to simulate, control and improve processes.
