Baumer
A perfect fit in five steps
Laser distance sensors ensure process efficiency in automated production processes with the help of non-contact measurements. When choosing the right sensor, factors such as measuring range, focus, beam shape or object surface as well as ease of use play a major role.
© Baumer
Laser distance sensors enable fast and highly accurate measurement of objects for reliable inline quality control, they provide measured values for high-precision positioning of objects or the y-axis positioning of a robot arm, or they measure the thickness for double layer control. Triangulation-based solutions are particularly suitable due to their almost surface-independent mode of operation. Compared to mechanical or tactile solutions, measurements are made without contact, which prevents both wear on the measuring device and damage to the product. But what should be considered in detail when choosing the right sensor?
Select measuring range and focus
Comparison of the signal changes of a laser distance sensor based on triangulation at short or long distances: The shorter the measuring range, the greater the changes on the receiving line.
© Baumer
It is generally advisable to select the measuring range as small as possible, as the precision of triangulation sensors decreases with increasing distance to the measurement object. Triangulation sensors determine the distance to the measurement object using an angle calculation: The sensor projects a laser dot onto an object. This object reflects the laser dot back to the sensor, where it hits a receiving element at a certain angle depending on the distance. The distance to the target in the sensor is calculated from the position of the light spot on the receiver element and the distance from the transmitter to the receiver element.
The change in position of the light spot on the receiver and therefore also the differentiation of distances are significantly lower at long range than at close range, which reduces the precision of the sensor.
However, the sensors cannot always be mounted as close as actually necessary to the
measuring object as necessary. One limitation could be the installation situation, for example, which prescribes a certain distance to the measurement object.
To optimize the performance of the laser triangulation sensor, work should be carried out as close as possible to the focus (or sweet spot) of the laser beam. The minimum diameter of the light spot minimizes interfering optical effects and therefore ensures the best local repeatability and precision of the measurement result.
Line or dot?
In many cases, the portfolio of laser distance sensors includes both point and line beam shapes, which should be used depending on the type of application. Line sensors offer a clear advantage in terms of measured value stability when measuring metals, wood or rough and structured surfaces, as an averaged measured value is output over the structure of the surface of the measurement object. Point sensors measure with an extremely small, focused light spot and are used for the precise measurement of the smallest objects, such as electronic components, or for the precise positioning of components.
No additional expense for protective devices
Different beam shapes for different surfaces: The laser line beam shape is suitable for metallic surfaces, for example, while the focused laser point is suitable for high-precision positioning.
© Baumer
Due to automatic adaptation to the optical properties of the measurement object, most laser distance sensors also provide reliable results within the specifications of laser class 1. The laser radiation from laser class 1 sensors may achieve a maximum power of <25.5 µW at a wavelength between 400 nm and 700 nm and is therefore harmless to the human eye. The sensors are quick and easy to install, without any additional protective measures. For this reason, they are the preferred choice in industrial applications.
Nevertheless, there must also be sensors with laser class 2: With extremely dark materials, such as matt rubber conveyor belts, most of the light is absorbed. As a result, only a small amount of light is reflected back to the receiving element of the sensor. If sensors with laser class 1 are used in such cases, they require a significantly longer emission time for a reliable signal. This reduces the measuring speed and the entire measuring cycle would be significantly longer. A laser class 2 sensor can provide a remedy here, as these can emit a larger amount of light and therefore the measuring cycles remain short. As a rule, no further protective measures are necessary here either, as the laser beam is harmless for short exposure times. However, looking into the beam or reflections over a longer period of time should be avoided.
Interface as required
© Baumer
To use the recorded measured values, they must be transferred to the various levels of the automation pyramid. This is usually done by transmitting an analog reference value via the analog output of the sensor or serial protocols such as RS485. However, the advancing development of Industry 4.0 places much higher demands on the networking of the levels of the automation pyramid and communication with the sensor. For this reason, Industrial Ethernet-based protocols are also offered for efficient integration into the networks of a modern factory.
Anica Drzewicki is Product Manager Optical Measuring Sensors at Baumer in Frauenfeld, Switzerland.
© Baumer
Industrial Ethernet-based protocols have various advantages for the user. Digital interfaces offer added value, particularly with regard to reliable, flexible production processes. For example, the sensor can be parameterized during operation via an integrated web server or the interface itself. In addition to distance values, secondary data can also be transmitted at high transmission rates to support predictive maintenance processes, for example.
Simply solve measurement applications
Andrea Memminger-Wäsch works in product marketing at Baumer in Frauenfeld, Switzerland.
© Baumer
In addition to the technical selection criteria, the ease of use of the sensors plays an important role in the selection process. Laser distance sensors with a web interface are an efficient solution here. This enables the sensors to be set without additional software, only a standard web browser is required. The sensors can be parameterized in just a few minutes via the graphical user interface and are then ready for use.
With the 'OM70' sensors from Baumer, for example, even reliable measurements on transparent products and the identification and suppression of interfering signals are very easy thanks to the simple visual display of the measuring signal and the option of graphically limiting the measuring range. An integrated monitoring function allows live analysis of the measurement results, which enables quick and immediate problem solving both during initial testing of the application and later during service or maintenance.
Ultimately, there is no one laser distance sensor that is equally suitable for all applications - a number of factors influence the selection. For this reason, Baumer offers a comprehensive portfolio of 'OM70' laser distance sensors with different functions, beam shapes, measuring ranges and laser classes.
TZ 1 OSADL
Support with license compliance
The use of open source software in industrial products is indispensable today. However, the use of this software requires suitable processes to be established in the company on how to deal with open source in order to achieve license compliance.
Baumer
Reliably recognize the finest details
Baumer is expanding the 10 GigE cameras in the 'LX' series with four new models. The cameras with Sony Pregius S sensors deliver 50 fps at 24 megapixels; more resolution is available with the 65 megapixel Gpixel models at 18 fps.
TWK
Detect alignment and speed simultaneously
TWK has expanded its family of inclination sensors with a special device that makes it possible to precisely measure the current orientation - i.e. the inclination or position (360°) - and the speed at the same time in a rotating application.
