AS-i FSoE Gateway
Quelle: Bihl+Wiedemann | Günter Herkommer,
Safely monitor movements
New in the Bihl+Wiedemann range is the AS-i FSoE Gateway BWU3509 with integrated safety monitor (FSoE stands for Safety over Ethercat).
© Bihl+Wiedemann
It acts as a safety master in the network and can take over all safety-related tasks without an additional safe controller. The usual PLC can still be used for the standard control of the drives. As a single master in the '1 gateway, 1 power supply unit for 2 AS-i circuits' version, the AS-i Safety Gateway has three two-channel safe inputs and can be supplemented by up to 31 two-channel safe inputs. Also onboard as standard are six fast electronic safe outputs, which can be expanded to a maximum of 32 independent safe outputs. The gateway is also AS-i Power 24V-capable and is therefore also suitable for use in compact systems. An additional AS-i power supply unit is not required. Last but not least, the integrated chip card makes it easy to replace devices.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
