Diagnosis
Quelle: Pilz | Lukas Dehling,
Retrieve sensor data remotely
Pilz is expanding its portfolio with the diagnostic solution Safety Device Diagnostics, which consists of a fieldbus module plus distributor and safe sensor technology PSEN. The new solution is designed to enable sensor data to be retrieved remotely.
© Mushroom
As diagnostic information, the solution provides data such as partial actuation, voltage surges and dips, temperature effects, switching cycles, bouncing, RFID identification/recognition. All additional diagnostic data provided by each sensor is intended to facilitate preventive maintenance. In addition to simple remote maintenance, for example via a web server, the integrated display on the fieldbus module ensures that information is not only available on the machine's operating monitors, but also directly in the control cabinet. According to the manufacturer, the fieldbus module serves as the only interface for the system bus of all connected safety devices, which should minimize the installation effort. It is also possible to connect third-party devices directly via the integrated I/Os.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
