Safety controls:
Quelle: Kendrion Kuhnke Automation | Inka Krischke,
Programmable with Codesys
The FIO Safety I/O 4DI/2DO safety Ethercat terminal from Kuhnke is a digital input/output terminal with four safe input channels and two safe output channels.
© Kendrion Kuhnke Automation
No special controller is required to function as a safe slave, as the solution is based on FSoE in addition to Codesys - so the safe Ethercat IO module can be used on any FSoE master. The solution is rounded off by the decentralized SIL3 safety controller FIO Safety PLC in accordance with IEC 61508. The configuration and programming are created with Codesys and transferred via Ethercat/ FSoE. Codesys provides safety modules such as emergency stop, two-hand operation and muting according to PLCopen. Users can also develop customized function blocks for their applications. According to the provider, this means that all FSoE slaves such as drives or I/Os can be safely controlled and continuously monitored.
Mushroom
Erlkönige discovered
For the first time this year, Pilz gave all visitors to the SPS IPC Drives trade fair in Nuremberg a glimpse of the innovations of the coming years - we also took a look around!
MES solutions
Test the services
Energy chains
Lying flat on its side
