SEW-Eurodrive and TH CologneFunctionally safe automation simply implemented
Edge computing combined with safety and security is changing the requirements for automation. One trend is to build automation systems from partially autonomous subsystems. This allows complex applications with cooperating robots to be implemented quickly.
<p>Figure 5: Standard operation and safe operation and analysis are integrated in one visualization. The safely (kinematically) reduced speed SLS (Safely Limited Speed) is used to monitor the Tool Center Point (TCP) and the Point of Interests (POI) to be defined.</p> © SEW-Eurodrive
