SafetyNews from safety-related automation
With increasing cycle rates, machine functions are becoming ever more complex - against this background, the topic of functional safety is becoming increasingly important. Computer&AUTOMATION shows a selection of current products relating to this topic in a picture gallery.
2 of 11
Miro Safe+ safety relay from Murrelektronik
© Murrelektronik
Safety technology is very popular in mechanical and plant engineering. Murrelektronik's Miro Safe+ safety relays achieve safety standards up to Performance Level e (PLe) in accordance with EN 13849-1. They are suitable for emergency stop, safety gate, light curtain and magnetic switch applications and have three NO contacts and one NC contact. They can be used with or without start button monitoring. The wide voltage input ranges from 48 to 230 V(AC). Miro Safe+ T 1 24 performs time management tasks. This module is suitable if both instantaneous and delayed contacts are required. Delays of up to 30 s can be set. Miro Safe+ T 2 24 has two time-delayed contacts and a width of 45 mm. The advantages of the safety relays from the Miro Safe+ range: clear assignment thanks to identification labels, LED status indicators on the front, cross-circuit detection that can be switched off, plug-in spring-cage terminals with quick-connect technology and coding elements that ensure that terminals are not mixed up.safety technology is very popular in mechanical and plant engineering. Murrelektronik's Miro Safe+ safety relays achieve safety standards up to Performance Level e (PLe) in accordance with EN 13849-1. They are suitable for emergency stop, safety gate, light curtain and magnetic switch applications and have three NO contacts and one NC contact. They can be used with or without start button monitoring. The wide voltage input ranges from 48 to 230 V(AC). Miro Safe+ T 1 24 performs time management tasks. This module is suitable if both instantaneous and delayed contacts are required. Delays of up to 30 s can be set. Miro Safe+ T 2 24 has two time-delayed contacts and a width of 45 mm. The advantages of the safety relays from the Miro Safe+ range: clear assignment thanks to identification labels, LED status indicators on the front, cross-circuit detection that can be switched off, plug-in spring-cage terminals with quick-connect technology and coding elements that ensure that terminals are not mixed up.
2 of 11
