Automation and mechatronicsNew products at Automatica 2016
Automatica, the biennial 'Trade Fair for Automation and Mechatronics', will exceed the number of exhibitors from 2014 this year. Computer&AUTOMATION shows a selection of the new products presented by the 825 or so exhibitors in Munich in a picture gallery.
4 of 20
20_Cable entry plate KEL-DPZ 24 from Icotek
© Icotek
Icotek has improved the KEL-DPZ 24 cable entry plate for the introduction of non-assembled cables. According to the manufacturer, the cable entry plate, which corresponds to the standard cut-outs of 24-pin heavy-duty connectors in terms of cut-out size and hole pattern, offers a high packing density that could not be achieved with conventional solutions with a comparable surface area. Cables, fiber optic cables, hoses or cable strands with diameters ranging from 1.5 to 22 mm can be inserted, sealed and simultaneously relieved against tension with the cable entry. With eight different versions, any number of combinations and diameter variants are possible. This is due to the different clamping areas for the cables. Tapered grommets on the back of the cable entry ensure that the cable is sealed twice. Openings that are no longer required can be securely closed with ST-B plugs from the supplier, and protection class IP65/IP66 is maintained.
4 of 20
