Robotics
Quelle: B&R Industrie Elektronik | Inka Krischke,
Control up to 15 axes
B&R is expanding its modular 'mapp Technology' software kit: 'mapp Robox' and 'mapp Teach' can be used to parameterize and commission any robot kinematics. With 'mapp Robox', any robot kinematics with up to 15 axes can be controlled.
© B&R Industrial Electronics
Developers are completely free to implement their kinematics and at the same time benefit from the features of 'mapp Technology' in terms of parameterization, visualization and diagnostics. In the next step, 'mapp Teach' helps to teach the robot which movements it should make. According to the manufacturer, teaching the paths and managing the processes is simple and convenient. 'mapp Technology' consists of encapsulated individual modules that provide basic functions that are parameterized graphically. This reduces the programming effort by an average of 67%. All modules are connected via 'mapp-Link': Based on the client-server principle, each component automatically retrieves all the required data from the other components.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
