Gripper arms
Quelle: Schunk | Inka Krischke,
Commissioning via smartphone, tablet and PC
Schunk is launching a mobile, anthropomorphic gripper arm on the market that can be intuitively programmed virtually, optionally reacts to collisions and enables different gripping operations in immediate succession.
© Schunk
The 'Powerball Lightweight Arm LWA?4P' and the 5-finger hand 'SVH' can be used with all common web browsers. An app is available for this purpose, which can be used on smartphones, tablets and PCs. Virtual sliders and an integrated 3D viewer enable axis-specific programming. The arm can optionally be equipped with an integrated, current-based force control. To speed up the changeover between different locations, complete procedures can be saved, called up depending on the situation and quickly adapted to the respective application scenario. Thanks to 24 V technology and fully integrated electronics, the lightweight arm is mobile and can be powered by a rechargeable battery. The lightweight arm has a dead weight-to-weight ratio of 2:1 and a dead weight of 12 kg (without base). It can handle loads of up to 6 kg dynamically and covers a gripping radius of approx. 700 mm.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
