Kuka
2nd generation palletizing robot
Kuka has completely redesigned the KR Quantec PA, which is now being launched in its second generation with optimized weight and centre of gravity as well as improved drive technology.
© Kuka
The robot from Kuka is specially designed for demanding palletizing tasks. Thanks to its reduced footprint, it requires very little space. In terms of cycle times, the robot is up to 10% faster than its predecessor model with a comparable payload: the robot type with a payload of 240 kg, for example, achieves 28.3 cycles per minute. The axis speeds have also been increased, which is advantageous for layer formation during palletizing or long 180° rotational movements, for example. The palletizing robot is also available in the 'Hygienic Oil' (HO) version to meet the requirements of the consumer goods industry, especially the food industry in the secondary sector. All axes and the energy supply system are equipped with NSF H1 food-grade lubricants. Both the robots in the HO version and the standard models are designed for the 'KR C5' robot controller.
Kuka
Midea delists Kuka from the stock exchange
Five years after the takeover of the Augsburg-based robot manufacturer Kuka, the Chinese investor Midea wants to delist the German company from the stock exchange. A so-called squeeze-out process has been initiated, Kuka announced on Tuesday.
Kuka
Cobot assistant for SMEs
A user-friendly cobot application for small and medium-sized companies that can be used without programming - a team of researchers from Belgium received the Kuka Innovation Award 2024 for this concept.
