Robots
Quelle: Hahn Robotics | Inka Krischke,
"Feels" his way
Hahn Robotics launches the Sawyer collaborative robot from Rethink Robotics on the German market. Weighing 19 kg, it has seven degrees of freedom/joints with a reach of 1260 mm in a 360° radius.
© Hahn Robotics
The robot, which is approved for protection class IP54, can implement what it has learned in the tightest of spaces. With its control sensors, it "feels" its way through devices. It also recognizes changes in the position of materials and can pick up objects that are not exactly aligned, realign them and place them correctly. The robot is able to perform tasks with a tolerance of 0.1 mm. Based on Series Elastic Actuators, a tolerant motion control system has been developed by combining mechanical compliance with force control, which, according to the supplier, enables safe, precise and flexible operation. The robot feels its way to the correct position without damaging parts, devices or itself. To receive and process visual information, the robot has an integrated camera system consisting of a head camera with a wide field of view and a Cognex camera in the wrist.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
