Predictive maintenanceThe latest products
Collecting and analyzing data: These are the basic requirements for condition monitoring and predictive maintenance solutions. Computer&AUTOMATION presents new products from these areas.
Following the certification of the "MRO-L200" LTE router from Insys icom, the basic variants (DSL, LTE, LAN) of the fully modular "MRX2" industrial router series are now also Microsoft Azure Certified for IoT. The routers have been pre-tested and verified to work with Microsoft Azure IoT services so that IoT solutions can be implemented quickly. The certified MRX3 and MRX5 router series capture data from a wide range of applications, regardless of protocols and manufacturers. By verifying the routers as Microsoft Azure Certified for IoT, direct coupling with Microsoft Azure projects via MQTT is possible. The "MRX" router series is based on a fully modular platform. The basic LAN, DSL and LTE variants are available in two housing widths with three or five slots. Expansion cards (MRcards) supplement the basic variants with selected modules such as serial ports, digital I/Os, Ethernet switch, VDSL/ADSL or LTE.
