Guidance systems
Quelle: Siemens | Lukas Dehling,
With integrated fieldbus diagnostics
With the new Simatic Afdisd active field distributor with extended fieldbus diagnostics, Siemens wants to enable fieldbus diagnostics for Profibus PA in the Simatic PCS 7 process control system.
© Siemens
The Simatic PCS 7 operator station allows users to call up real-time information on the status of their fieldbus installation - for example on voltage, current or any bus interruptions. According to the manufacturer, this enables them to detect impending faults at an early stage, initiate countermeasures in good time and thus increase system availability. The extended fieldbus diagnostics are based on monitoring the bus physics (physical layer information). Information such as current and voltage is recorded and visualized. For example, faulty or disconnected field devices can be easily detected and any bus interruptions can be localized and rectified remotely if necessary. Changes in current and voltage levels can also be detected without additional third-party hardware and software tools.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
