Visualization software:
Quelle: Eaton Electric | Lukas Dehling,
With automatic object detection
Eaton has further developed its Galileo visualization software for touch panels from the XV and XP families and for PC runtime solutions for operating, monitoring and controlling machines.
© Eaton Electric
Users of previous versions can upgrade their devices and projects to the new version thanks to upward compatibility. According to the manufacturer, new functions in version 10 help to further shorten the project planning and commissioning phase. For example, as soon as the user clicks on an object or symbol on the user interface, its most important attributes are now displayed directly on a sidebar. With the search and sort functions, which are designed to enable screens, variables, bitmaps and scripts to be found quickly in a project, the software displays the results in list form. Automatic object recognition is designed to allow simple positioning and alignment of all objects on the user interface. So-called styles ensure a uniform appearance of objects throughout the entire project. For example, if the user changes the color of an object, this change is applied to all objects assigned to this style. Thanks to the screen adjustment function, users can switch between 4:3 and 16:9 format in the project.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
