Displays
Quelle: SE Spezial-Electronic | Lukas Dehling,
Viewing angle of 170°
The 12.3-inch IPS TFT display in 24:9 format from SE Spezial-Electronic is suitable for both indoor and outdoor use
© SE Special Electronics
According to manufacturer Winstar, it is characterized by 24-bit colour depth and offers the user a wide horizontal and vertical viewing angle of 170° each, a contrast ratio of 1000:1, a high resolution of 1920 x 720 pixels and a luminance of 800 Cd/m². The fully bonded PCAP touchscreen with 1.8 mm thick front glass and black frame has its own Cypress CYTMA568 multi-touch controller with I²C interface. The dimensions of the display are 313.4 mm x 135.86 mm x 10.6 mm, the active area is 292.32 x 109.62 mm². The display is controlled via a dual-channel LVDS interface. An operating temperature range between -30 °C and +85 °C and a storage temperature range between -40 °C and +95 °C should predestine the display for use in information systems and industrial applications outside buildings as well as in vehicles and construction machinery.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
