Displays
Vibration resistance of 6.8 G
MSC Technologies has expanded its product range with three TFT LC modules from Mitsubishi. The industrial displays have a vibration resistance of 6.8 G and are designed for operation in a temperature range from -40 °C to +85 °C.
At the same time, all models offer a brightness of 1500 cd/m² and a contrast ratio of 700:1 for readability even in bright environments. The service life of the LED backlight is specified as 100,000 hours. The TFT Dìsplay AT070MJ11 in TN technology has a WVGA resolution with 800 x 480 pixels and a screen diameter of 17.78 cm (7.0 inches). The viewing angle is 140 degrees vertically and 160 degrees horizontally. The panel has an LVDS interface. The active area is 152.4 x 91.44 mm, the dimensions of the LC module are 169.8 x 109.7 x 8.9 mm. The 26.42 cm (10.4 inch) TFT display AT104SN11 offers an SVGA resolution of 800 x 600 pixels. The viewing angle is specified as 160 degrees (symmetrical). This LC module is also equipped with an LVDS 6/8 bit interface. The display area is 211.2 x 158.4 mm. The AT104XH11 LC module with XGA resolution (1024 x 768) also has a diameter of 26.42 cm (10.4 inches). The display surface of all three Mitsubishi products has an anti-glare film and a 3H hard coating.
