Microsyst
Up to 100 m reading distance
Both the outdoor and indoor versions of the miline model from Microsyst have a dustproof and waterproof housing.
© microSYST
The displays for outdoor use are also equipped with outdoor modules as well as technology modules. The Microsyst models start at 32 x 16 pixels, with a maximum of 128 x 48 pixels possible in standardized steps. In conjunction with high-contrast and bright LED technology, this enables reading distances of up to 100 m. The coupling of several displays to enlarge the visualization area is taken into account at the factory. Multi-page displays can also be implemented. A special microcontroller system enables various components to be controlled via fieldbus (e.g. Profibus or Profinet) using central software.
The visualization options include fonts, text attributes, graphics, pictograms, bar graphs and images, in several colors, as a stand-alone font, scrolling or with a view function, complete or in sections. The background color can also be adjusted as required.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
