Multifunctional lights
Quelle: Pfannenberg | Lukas Dehling,
Signals dangerous conditions
The Quadro LED-HI multifunction light from Pfannenberg is used for visual signaling of hazardous conditions and for indicating the status or fill level of machines and systems.
© Pfannenberg
Possible areas of application include machine and plant operation in industry, building security and regulating vehicle movements on company premises. Thanks to the IP66 or IP67 and IK08 protection ratings, the lights are also suitable for outdoor use. The luminous intensity of the Quadro LED-HI can be flexibly adjusted up to an output of 75 cd. The user can flexibly set the operating modes on site at any time: Permanent light, flashing light with frequencies in 1 Hz / 2 Hz as well as flashing light with frequencies in 0.1 Hz / 0.5 Hz / 0.75 Hz / 1 Hz / 2 Hz. A 24 V version with a functional range of 11 V to 60 V (DC) and a 230 V version with a functional range of 90 V to 253 V (AC) at 50 Hz/60 Hz are available for the power supply. The Quadro LED-HI is designed for an ambient temperature between -40 °C and +55 °C.
Kontron
Managing Board expanded
Kontron expands its Management Board with Philipp Schulz and Dr. Johannes Fues. As COO, Schulz will be responsible for the Aerospace and North America business units, while Dr. Fues will assume the position of COO for the GreenTec business unit.
Kontron
Control panel series updated
Kontron has developed a new generation of its Control Panels which, thanks to the more powerful Arm NXP i.MX8M Plus processors, provide a significant performance boost compared to previous models.
