SR System Electronics
Panel PC series expanded
SR System-Elektronik has added a compact 7-inch and a 10.1-inch device to its range of panel PCs for installation.
The SR-Line panel PCs from SR System-Elektronik have an optically bonded PCAP touch sensor, which also improves stability. IP65 protection against dust and water is achieved on the front. The embedded PCs are designed for 24/7 operation and are equipped with the Pentium N4200 QuadCore Apollo Lake board. The PC board has 2 Gbyte SDRAM, 64 Gbyte SSD hard disk, a GbE LAN connection and two USB 3.0 ports. The fanless Panel PCs are supplied with rear mounting brackets for easy installation. As an option, the Panel PCs can be pre-installed with the latest Windows 10 IoT Enterprise 2021 LTSC operating system. Alternatively, Linux can also be installed.
