Wachendorff Process Technology
Panel PC made of stainless steel
Wachendorff Prozesstechnik has introduced the robust, waterproof stainless steel panel PCs of the 'PhanTAM' series from Aplex Technology.
According to Wachendorff Prozesstechnik, the series improves on previous stainless steel solutions with an updated Intel 11th Gen. Core i3 (Dual Core) / i5 (Quad Core) BGA processor, an updated slim front bezel design, special hygienic screws on the rear housing, the ability to be used in landscape or portrait mode, and a waterproof antenna cover that eliminates the risk of bending/breaking antennas. The series has IP66 and IP69K certified protection with M12 connectors. The fully enclosed 304 stainless steel (or optional 316 stainless steel) housing is suitable for the food and beverage industry due to its high corrosion resistance and germ resistance, helping to prevent any bacterial contamination. The hygienic screws with blue silicone rubber O-rings prevent the accumulation of water, dust and bacteria while providing flexible mounting options. By adding waterproof antenna covers, users can utilize a range of antenna options (4G LTE, 5G, BT and Wi-Fi) and not have to worry about the antennas bending or breaking.
