Panel PCs
Quelle: Comp-Mall | Lukas Dehling,
Optionally with remote maintenance
Comp-Mall is expanding its panel PC range with the PPC-F19B-BT multi-touch panel PC with a 19-inch (5:4) screen diagonal. The model is available with either resistive single-touch or projected capacitive multi-touch.
© Comp-Mall
The computing unit is based on the Intel Celeron J1900 quad-core SoC and 8 GByte DDR3L SO-DIMM. The display resolution is 1280 x 1024 pixels with a contrast of 1000:1. With its metal housing, the model is designed for use in harsh industrial environments and has an IP65 rating on the front. The industry-optimized inputs/outputs include 2 x Ethernet channels, SATA3.0 for 2.5-inch HDD/SSD storage media and mSATA, VGA, HDMI, USB 3.0, USB 2.0 and COM. The Panel PC has two PCIe mini card slots for expansions. One slot supports mSATA, so that an additional storage medium can be used alongside the 2.5-inch SATA drive.
A power supply of 9V to 36 VDC is required, a mains adapter is included. The temperature range extends from minus 10°C to +50°C. An optional dual-band WiFi interface and Bluetooth v4.0 can be integrated for wireless communication. A special feature is the optional iRIS-2400 module, which is used to maintain and manage the computer remotely.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
