Touch panels
Quelle: Comp-Mall | Lukas Dehling,
IP64 protection on the front
The AFL3-W15B-H81 model from Comp-Mall has a screen diagonal of 15.6 inches with an installation depth of 32 mm and is IP64-protected on the front. It is equipped with PCAP or resistive touch and offers HD resolution (1366×768) and a contrast of 700:1.
© Comp-Mall
The touch panel PC is supplied with the Intel Core i7/i5/i3 processor series (TDP 35W), a maximum of 16 GB DDR3L SDRAM, an mSATA slot and a 2.5-inch SATA 3Gbb/s HDD. The flat display with a scratch-resistant 6H surface should be easy to clean. Operating systems such as Win 8/8E or Win 7/7E are supported. The dual-band WiFi IEEE 802.11a/b/g/n/ac with 2.4 and 5 GHz interface as well as Bluetooth v4.0 should enable fast and reliable data transfer rates for wireless communication. The range of interfaces includes: USB 3.0, USB 2.0, COM, 2x GbE LAN, camera, HDMI and audio with built-in speakers. All interfaces are led out to the bottom. Optional 1D/2D barcode scanners and RFID readers are also available. The operating temperature range extends from -20 to +60 °C with a controlled fan. Thanks to the VESA standard, it can be mounted on the wall, on the arm, in the control cabinet or in the panel.
Kontron
Managing Board expanded
Kontron expands its Management Board with Philipp Schulz and Dr. Johannes Fues. As COO, Schulz will be responsible for the Aerospace and North America business units, while Dr. Fues will assume the position of COO for the GreenTec business unit.
Kontron
Control panel series updated
Kontron has developed a new generation of its Control Panels which, thanks to the more powerful Arm NXP i.MX8M Plus processors, provide a significant performance boost compared to previous models.
